We have a new blade installed on the vinyl cutter today.
As a reminder the pressure setting should only be changed for non vinyl projects and should be reset to 115 when you are done. If you feel the need to raise the pressure for your vinyl projects it is very likely that the material is in upside down.
Thanks.
