Tried to light the forges for a safety checkout today. The small forge seems to have a pressure or airflow issue. when lit it only put out a gentle flame and would not get to the usual jet regardless of where the regulator was set.
I then tried to light the large forge and could not get it lit at all. the issue seemed to be a lack of pressure here as well but the tanks may be empty. If it was the tanks, there were not two replacement tanks of the same size in blacksmithing.
I’m not sure what issues you had. Both forges operated fine this morning. I did notice that the ball valve to the fan was closed on the small forge, which meant there was no air getting to the burner. Since there is a choke on the fan, the valve is not needed - so I removed it. One less thing to go wrong.
For future reference, here are detailed instructions on how to light the forges. This will be printed and posted near the forges.
Small Forge Lighting Instructions
Turn on fan
Open tank (one full turn)
Adjust regulator to 5 psi
Close tank and wait 5 seconds
Hold lit hand torch across opening
Replace hand torch
When forge is hot (about. 5 minutes) set regulator to 1 – 2 psi
Small Forge Shutdown Instructions
Close tank
Leave fan running for as long as possible
Turn off fan when leaving
Large Forge Lighting Instructions
Plug in fan
With all three inline valves closed, open both tanks (1 full turn each)
Open all three inline values
Adjust regulator to 7 psi
Close main valve (closest to regulator)
Open door on one side of forge (set on the highest pegs)
Open main valve
Replace hand torch
When forge is hot (about. 5 minutes) set regulator to 2 – 3 psi
Honestly i completely forgot that valve was even there on the small forge since I have not had to adjust it since we upgraded to forced air.
As for the big forge im not sure why i couldnt get it lit. I must have missed a step in the lighting process but i have no clue which one lol. Glad to hear it wasnt an actual issue. Thank you for looking at them @Clifford_Bohm
Hmm. The interesting question is, “Who closed the valve?” It indicates that someone is using the forge who does not understand its operation. At least the problem won’t happen again (since the valve is no more).
