The belt on the 6" wide belt sander (currently located next to the spindle sander) has broken, and none can be found here in the space. This tool is currently down.
More belts have been ordered.
New belt installed. Please learn about belt tracking before using.
Charlie
Is tracking now an issue with new belt? It seemed not to be a problem when I used it last, which was when the belt broke.
Whenever the belt is replaced, you have to get it tracking right without too much tension on the belt. It works fine now. As it wears, the tracking may need adjusting. Please, find out how to do it if you are not experienced with the process.
