Hello! I would like to schedule a check-out for the rolling mill in the jewelry area. If time permits, I would also love to review the procedure for performing a leak test on the Smith Little torch closest to the wall. ![]()
Hi, Emanne! I can give you a checkout for the rolling mill. Have you had a checkout for the Little Smith torches? If so, the leak testing is checked at the same points on the propane tank regulator, as the oxygen tank regulator. I’m also happy to give a refresher, if you’d like.
The rolling mill checkout doesn’t take long. Would tomorrow work for you? I’ll be at the space around 2:30 ish pm. Would 3 pm or 4 pm work?
Hi Heather,
I can come in at 3 PM!
Great; see you then!
Good evening
I have signed up for the CADL pass and would like to learn more about the jewelry area and possibly get checked out on some of the equipment
Retired so most anytime will work for me
Thanks
Hello & welcome to our space! Would tomorrow, Wednesday the 22nd, at 11 or 11:30 am work for you? The torches take approximately 45 min for a checkout. The rolling mill & hydraulic press take about 20 min each & then another 10~20 min. to talk about the rest of the Metalsmithing area.
I’ll be at the space at 11. I’d prefer to do the checkout at 11 or 11:30 as I have other things in the area I’ll be working on. If either of those times work, ring the bell at the front entrance & I’ll let you in. If they do not work, I’m tagging @JamesFriend to see if he is available Saturday to give you the torch & rolling mill checkouts. Or maybe, @Arialia can help you out. Otherwise, I’ll be available again on Monday at 11:30 am.
