I have some wood louvers I would like to restore that would be super tedious to sand.
so trying to find an easy way to take the old paint off. is there a sandblaster in the space that could be used for this purpose?
Interesting suggestion. How does this compare to GooGone?
Thanks @Jtempkin i’ll give it a try, have you had any luck removing varnish with this too?
It’s way better, and as a goo you can lay plastic over it and let it sit for a day or two. Then wipe/scrape goo off
