Regulator issue
Propane regulator dial idling at 7 PSI indicated
@David thanks for the heads up - I’ll be in the space after work so I can take a look then.
@David and I took a look at it. Problem seems to be the gauge itself so probably our best course of action is to replace the gauge (got a tip from @Lou that they’re fairly cheap) but hopefully we don’t need to replace the whole regulator.
@Lex @BoardMembers fyi
