I keep getting this message when I am trying to do something on the laser printer. Even files that used to work are getting this message. What am I doing wrong?
**Affected Tool or Resource:**laser printer rd works Team, Group or Volunteer who usually handles this type of ISSUE or REQUEST (Please tag using the @ symbol. Start by typing @TEAM_ to find most responsible teams): [REPLACEME]
[REPLACEME]
Please remember that VOLUNTEERS will be helping to resolve this issue. While everyone works very hard to fix things quickly, sometimes things take time. Please consider volunteering to help keep everything working well at our space!
Ahhh. Ok. There’s more to the message that you haven’t included then that will shed more light on the situation. Common error messages:
Frame slop: your job would cause the machine to run out of its bounds. Usual causes: picking the wrong corner as your start point with the head close to an extent or being too close to the extents when doing a scan mode burn (the machine has to over travel your job while scanning. At higher speeds this can be quite a lot of overtravel as the head needs more room to switch direction. )
Machine protected: the machine doesn’t think it’s safe to continue. Usual causes: the water pump isn’t on or the lid isn’t pushed all the way down (check to see that you can hear the switch click).
Yes. I still am lost with my other files though I can only get my logo to
work right. And of course I dropped my flash drive someplace and I lost
even that file!
