Polishing Lathe in Jewelry
Hey @Heather @jody,
I’d like to use the polishing Lathe to finish a wood pipe with carnauba wax. I can buy my own wheel if we don’t have one that is used with carnauba wax, but I don’t normally see anyone in Jewelry when I’m in and the sign on the polishes say ask anyone for help. Sooo do you happen to know if we have a carnauba wax wheel/could I use it with my wood or should I bring my own? And, is there anything special I should know before using it?
Thanks,
-Adam P
We don’t have any wheels that have carnauba wax. You’ll have to get your own wheel. If you’re looking locally, try to find something with a small arbor hole. The usual 1/2" arbor hole is too big for our machines. Something like this would do:
https://www.harborfreight.com/power-tools/polishers-buffers/polishing-pads-wheels-accessories/buffing-wheels/4-inch-buffing-wheel-34743.html
You could also pull out the stitching if you’re looking for a light even polish over a rounded surface.
I can show you how to use it. Will you be around this weekend? Tonight? Macie has to do some cutting boards so I’ll be this evening after dark.
I’ve got to leave at close tonight but I might be able to stop by late tomorrow night, like 9ish. Also do you/does anyone happen to know a good place to buy carnauba wax?
Johnson’s Workbench in Charlotte may be a good place to look for carnauba wax.
Thanks!
@jody will you be around tonight, or should I try to schedule a different time this week?
Sorry, I’ll be busy this evening. I can come in this week (Mon-Thurs) sometime in the afternoon/evening/night.
Whoops. Things got cancelled and now Macie wants to work at the space tonight. I’ll be there 9-9:30 this evening.
I’m going to try to come in on Wed night, pending coordination for bedtime and such. I’m also coordinating some Ironworks checkouts but would you be available around 8:30-9ish?
Looks like it would probably be more likely to be about a half hour later, but should be able to make it that night.
@jody does ~9-9:30pm work okay for you tomorrow night?
That works. See you then!
