Hi All,
Anyone free this week to do a plasma cutter checkout?
Best,
Henry
Hi All,
Best,
Henry
@Mike-L Handles the welding area check outs.
I will be in the space thursday evening to work on the air compressor and install new consumables on the plasma cutter.
My shift is friday evening 6:30-9
I also plan to be available over the weekend while working on an SOP for the machine
We have a Plasma cutter? is it just the torch on a cart or is it attached to CNC?
Sounds good! So should I come in thursday or friday then, or does either work?
Thank you,
Henry
Either works
20 stupid characters
We have a multi process welder that is capable of DC ARC welding, DC TIG welding, and plasma cutting up to 50 amps when plugged into a 220 socket. It can also run on 110 but at much lower amperages. I am more than happy to answer questions while making the SOP this week.
Currently that is the only plasma cutter. However I do have plans for a dedicated plasma cutter to go on a diy cnc table. Currently thinking a 4’ x 4’ table
Hi!
Ill be in and the space all day today, so just let me know when works for you for the checkout!
Best,
Henry
Just realized you said 6:30-9 im here just working on some small tasks, im in the white and black shirt
