(Old) laser cutter, ironworks unavailable Monday Dec. 22, 2025
There will be some work going on Monday, Dec. 22, in Ironworks that requires shutting off the circuit to the room. That will also cut off the laser cutter room (the old laser cutter, not the Trotech, which will be available), the hanging lights in the machine shop area, the hanging outlets (but not lights) at the activity tables, and some older outlets in the jewelry area (but not lights, unless they’re plugged into the outlets). We’re planning on this taking much of the day.
We’re doing it Monday because that’s typically our slowest day. But if you’re planning to do some last-minute forging or laser cutting for gifts, you’ll need to pick a different, earlier, minute.
