I would like to check out the mig welder, grinder, vise, and other small hand tools in the metal shop on thurs the 15th. I probably won’t need each one all day.
Paging area manager @Mike-L. I would be interested in attending a MIG checkout as well.
I am available from 5 to close on thursday. I can provide checkouts for the mid welder, plasma cutter, stick welder, and grinder. Let me know what time works for you and wear cotton clothing for safety
Do you know if the tig welder is working? and can provide a checkout? thank you,
The tig welder is not yet operational
OK by me. I’m experienced with 2 yrs of stick welding so I hope mig is easier. at least it seems that way to me as an outsider. I have accesse to a vary small welder (3/32 is as high as it will go.). I used to play with more like the 1/8 range. I plan to also bring a friend who has probable done muffler welding with mig. what I need is about that delicate, so maybe I can pay someone to do parts of this If I can’t avoid blow thru, as the plate I’m welding to is at about 1/32 to 1/16. which I feel doing in the mig is usually proven not blow thru, nor tiny stick. looking forward to it.
Hey mark! I noticed a voicemail from you about checkouts. Did you get the hook up?
thx so much for letting me use the mig, one machine works like a dream. can weld 1/14 bar stock to 1/16 steel. it’s a thing of beauty and I will bring a friend on thur
