Lost spring for wood lathe tool
I dropped the spring tip drive center while using the wood lathe today. The center pin and the spring both came out of the tool. I found the pin but not the spring. I will try to replace the spring on Thrusday. It should still work fine with the set screw, but I thought it should be known in case someone wanted to use it!
Spring has been replaced!
