I am looking to do welding, bending, soldering of small metal pieces.
Hey Roger, I’m Adam the Welding area manager, I can give you a checkout on the welders, as for bending, we can do hot bends with the forge or the ironworks’ oxyacetylene torch(I can give checkouts on both of those as well), we don’t currently have a permanent setup for soldering, but I can show you the basic process I’ve used in the past. What days work for you?
Thank you Adam, I am available Saturday 1/17/26 12 to 2pm? or Thursday 1/22/26 4-7pm.
Both of those days work for me. I won’t be available on Saturday until after 1pm, the forge checkout can take a minute so if you’d rather do it all in one day, Thursday might be best.
Hello Adam, 1pm Saturday sounds good to me. I will be working in the red laser room. I do not necessarily need a forge checkout but if only takes a minute maybe okay…I can go past 2pm if it takes a little longer. But if Thursday works better I can do that instead
Let’s shoot to do the welding checkout around 1pm on Saturday, and if we’ve got time I can give a check out on some other tools that could help with what you’re looking to do.
Hey, is there room for me to join this checkout today?
Yes! You’re more than welcome to join.
I would like to get checked out on the welder and bending.
Hi Bob, I can give a checkout on the welders, most bending will require checkouts on other tools. I’ll be in this friday from 4-7, if that doesn’t work tell me a day that works and I’ll tell you if it works for me.
I will be there this Friday. See you then.
Bob Nees
