Hello. I am interested in seeing if the laser engraver. Brian suggested I ask if someone will be around on Saturday, 1/5/19 to show me the laser engraver and do some quick/basic tests on the low density cork I have. Look forward to hearing back.
Thanks!
David
Hi David,
If you’re still interested in coming down I’m sure we can work with you to try out the laser cutter today. I should be here past 6:00, so if you need to come down later, just shoot me a message and let me know when you’ll be stopping by.
Hi Brian,
Thank you for your response. I am putting some things together and will be there probably around 3:30. Hope that works.
David
That’ll work great! We’ll see you then!
Sorry Brian, I will be there at 4:30, which is what I meant to say due to the drive time. Will that still work? On the road already.
Yep not a problem. Either myself or @jody will be able to help you out.
This topic was automatically closed 14 days after the last reply. New replies are no longer allowed.
