There seems to be a “wobble” on the laser cutters Y axis. It’s possible that the belt needs cleaned out from tge dust and grime has anyone done this before? Possible that the just need the tension on the belts?
After cleaning all the rails and lubricating , there isn’t an improvement. I did find the back left rail mount had a loose hex that won’t tighten
Possible solution: @RealCarlRaymond @jody
Update: i have cleaned and tightened everything i can see. There is a reduced amount of wobble now but it’s still there. Here is a graphic at 50mm and the theoretical max speed
Today i leveled the honeycomb bed and cleaned out the z axis belt chamber. I also tightened the mirror to fix an issue with the back right focus
