Hello
I am having an issue with the laser cutter where it doesn’t cut evenly across the entire workpiece. Some areas cut cleanly; while others barely etch the surface, even though the material is the same throughout. ![]()
I have tried adjusting power & speed settings, but the inconsistency persists, making precise cuts difficult. Could this be a focus issue / is there something else I should check? ![]()
I have already cleaned the lens and mirrors & I’ve ensured that the material is lying flat on the bed. However, the problem seems to be worse on larger pieces, leading me to suspect a possible misalignment or an issue with the bed leveling. Has anyone else faced this, and what steps did you take to resolve it?
Checked Issues and Requests - Lansing Makers Network Looker Training guide related to this and found it quite informative.
I found this Laser Cutter Maintenance Guide helpful for troubleshooting, but I’d appreciate any additional tips from those with experience dealing with uneven cutting performance. ![]()
Thank you !! ![]()
