Does anyone know of powder coating services? Or if anyone here powder coats?
I have the supplies to do it myself but not an oven large enough. The piece would be 4.5 feet by 7 feet.
Best,
Henry
Best,
Henry
You should talk to Elite Powder Coating. They have an oven larger than that.
https://elite-powder.com/
I’m assuming the piece can’t be broken down less than 7 ft? I have a powder coat oven in the back of LMN that can fit a motor cycle frame. It needs to be fixed up a little though
Im down to help fix it up! Depending on the max size I may be able to adjust the height since I haven’t welded on the legs yet. I could maybe make it a bit shorter.
What are the dimensions inside?
Best,
Henry
Sorry for the delayed response. I’m not able to be at the maker space for a bit
I’m afraid i don’t know off hand and it’s buried under stuff for the maker market.
How soon did you want to start powder coating?
Hi Evelyn!
Sorry for my late response, no worries on the powder coating oven, Ive decided to go with a clear enamel spray coat. I would still be interested in getting it set up for future projects, so if you ever need anyone to help or take a lead on it I would be down! But I also remember that there might have been some roadblocks/concerns to setting it up, so no worries if it’s a future thing!
Best,
Henry
