Jewlery checkout request - Acetylene torch
Hello! Am I able to be checked out on the acetylene torch in the jewelry space? If possible, I would also like to get checked out on the small drill press at the same time/after, but no worries if not. I am available anytime Saturday or Sunday (7th or 8th of November).
Hello, Lillian! I can give you the authorization/check out on the Acetylene torch & show you how to use the drill press on Sunday at noon. I have the Michigan Silversmith’s guild meeting that starts at 1 pm & goes until 3ish. So, if noon doesn’t work 3:30/3:45 could also work.
Great! 12:00 works. See you then!
Great; see you then!
