Furniture moving help
The crafts area needs to be reorganized to make space for some new machines. If anyone is feeling very strong and motivated, this shelf needs to move to the brick wall
Do you have a day and time in mind? Or can it be moved whenever?
It can be moved whenever, I’ve emptied it out but the space for it to go still has stuff in it. I will probably be able to move that tomorrow.
Charlie said the back needs to be cleared out before August so it’s not a huge rush
I can help thursday if im not doing checkouts.
The table is moved out from the corner where the shelf should go. The crafts area is hard to use right now, sorry for any inconvenience
Adam and I have moved the shelf and discovered the lower cabinet is extremely top heavy even with shims. We couldn’t figure out how to secure it to the wall (as it had been with the drywall on the other side) so any help with that is appreciated.
For now, it is held upright with the shelf and has a warning on it. If anyone has experience with masonry and wants to give it a go to secure it, it would be much appreciated!
I can bolt this base to the wall. It it where you want it now? Or should it go left or right any?
I fastened it where it sits. Let me know if you need it moved.
More furniture needs to move: the flat file should go against the wall in front of the window, and the tall shelf needs to be fastened to the wall.
Thank you everyone for your help and also patience while the space gets back into shape
