Affected Tool or Resource: White bandsaw blade broke.
Team, Group or Volunteer who usually handles this type of ISSUE or REQUEST (Please tag using the @ symbol. Start by typing @TEAM_ to find most responsible teams): @Tony, @laura_rogers
Bandsaw blade broke and needs replacement.
I will be in tomorrow to replace it. Do you know what size blade it was?
EDIT - I will be in SUNDAY to replace this. Please use the other bandsaw for the time being.
Please tell me what you can about how this happened. Did you try to cut a tight corner, for example? What kind of material were you cutting? How thick was it?
Hi Tony! It happened as I was finishing a straight relief cut in my project. The blade broke as I was moving it back out of the cut (the cut itself was only about an inch, inch and a half into the wood). The piece of wood was a walnut chunk, approx 3-ish inches thick. Not enitrely sure why it broke, my guess is I either was moving the wood back too quick or had turned it slightly when backing the blade out
The blade was off the drive wheels, but not broken. I put it back on today.
I did notice the rubber strip on the bottom wheel was damaged, and needs to be replaced. I’ll get another one. In the meantime, please let me know if there are any issues with it.
