3d Prussia printer
I’m not familiar enough with the printer but was trying to print out my first file. Could not get the filament to extrude. Not sure if there is a clog in the nozzle or if it’s a user error.
Tried to load and unload a white pla filament several times. Could not get the printer to extrude the melted filament. I also tried to print from 3 separate files. None would print.
If you find there is nothing wrong with the printer. I’d like to set up a time to work with you to print my first file.
Howdy Kirk
I just took a look at it as of today (3/8/2025) and it turns out the tension screws on the extruder motor were a tad loose, which I believe caused your inability to feed filament. I’ve tightened those up and double checked the Z offset In case it got screwy while I moved it. It should be all set now.
TLDR: the printer is fixed.
Leif Swanson
