Hi all,
The 3d Printer is having an issue with its Z calibration. When I started it up today, it was saying that there is an issue with the distance of the nozzle from the plate and needs to go through a first layer calibration. I ran it through the basic xyz calibration. Then tried the first layer calibration but I am not sure how to actually adjust it properly when running that.
It will need someone more experienced calibrating the printer to perform and fix it.
Howdy Jeff
As of today (3/8/2025) I took a look at it. I believe the Z offset got screwy while I moved the printer when I was reorganizing the room. I just set the Z offset again and it appears to work just fine now. The tension screws on the feed screw were also loose and I took care of that as well.
TLDR: the printer is fixed.
If issues persist please don’t be afraid to reach out.
Leif Swanson
Thanks Leif! The new set up is looking great! Really like the led light set up.
Seconded!
