I dialed in some settings for the Trotec laser on white 5mm EVA foam tonight. I left my swatches near the computer and made a Material for it in the Trotec software. I believe if you’re using a darker color, you would need less power or more speed, but that’s something that would need to be tested. At least we have some numbers to start with now.
@Chris_Drake I thought you might be interested in this.
Thanks! Also, since you seem good at this, how are you with acrylic? It cuts very well on the Trotec but I have yet to achieve perfect edges. If you have any tips I’d love to hear them or maybe we could meet up one time.
I am not super experienced at doing laser cutting, but I do have some experience at iterating until I find a good setting for something.
It took me a couple hours to find a good setting for the EVA foam but in doing so, I think I could figure out different settings faster for the next material.
I just laid out some squares and picked some settings I thought might work and kept dialing in what seemed to be working vs not.
I’m not sure if taking multiple passes would help get cleaner lines or if that makes the lines less clean since there may be a step in the side at that point. If you have time, I’m usually in volunteering on Friday nights after 6:30p and I’d be willing to chat about my limited experience with the laser.
The important thing is to check the MSDS for the foam you’re using to make sure the material won’t break down into a chloride gas or anything else toxic. Decomposition product I believe is what you’re looking for on the MSDS.
