I’ll be running a CNC router checkout Monday evening at 7:30pm. Anyone who is interested is welcome to join in. This consists of first using the V-Carve software to generate some G-code, then going into the wood shop and running it on the machine. This one takes around an hour or a little more.
I’m definitely interested and plan to be there. I am not a member as of yet. Can I submit everything along with my first payment that day or should I just go through the process on the website?
There’s an orientation when you become a member which takes 30-45 minutes. If you can come around on the weekend to join up, then you can get that out of the way first.
But you can still attend the checkout as a pre-member if that works for you.
Awesome. Well I will be there regardless. I’ll get the orientation out of the way as soon as possible. Thanks for the info.
I’d like to show up and get a refresher as well… if that would be ok? I hear Monday will be snowy, so if the weather is more than I want to handle, I’ll be a no-show (FYI). Thanks Carl.
@Justin_Crane @halgren @Lou:
I’m going to call a snow day on this checkout. It looks like snow all day. We’ll reschedule when things clear up, probably later this week.
Makes sense. Thank you.
Now that it’s about to warm up, I propose we reschedule this for Saturday at 2:00pm. Let me know if that works for you.
I won’t be able to make it but I will look for more opportunity in the future.
Carl I am interested in Learning how to plane wood using the CNC. I just received my planing bit in the mail. I could be there Saturday. Would that be something we could do?
@krussell: You’re welcome to come for the checkout, though it won’t specifically cover resurfacing. However, it’s a starting point for everything else. Afterwards we can go over how to do a surfacing operation.
