Team, Group or Volunteer who usually handles this type of ISSUE or REQUEST (Please tag using the @ symbol. Start by typing @TEAM_ to find most responsible teams): @TEAM_DigitalFab
Pronterface will not load G-Code of item, even ones that have been 3D-Printed before. Error message says, for example, self.fgcode.prepare(open(filename,“rU”),
IOError: [Errno 2] No such file or directory: u’/home/LMN/Downloads/Ray_Kurtis/Hex_Planter/CactusPot-01_export.gcode’
Please remember that VOLUNTEERS will be helping to resolve this issue. While everyone works very hard to fix things quickly, sometimes things take time. Please consider volunteering to help keep everything working well at our space!
Ok… Seems that I forgotten how to convert .stl files into .G-Code. I figured it out. Suggestion: can this be added into the current SOP for the 3-D Printer? I’ve done this in Cura, but I know that this can also be converted via Slic3r.
Thanks in advance!
UPDATE: OK @jfahner , I was told by Brian that you wrote the preliminary SOP for the current 3D printer. Could we add the Conversion step as well?
The SOP has now been updated to include slicing .stl’s to produce .gcode. I swapped it out at the space last night. Let me know if anything is unclear or needs improvement.
