Team, Group or Volunteer who usually handles this type of ISSUE or REQUEST: @TEAM_DigitalFab
Hello again. I was told by Evelyn Down that if I wanted to learn / check out the laser cutter I should post here to schedule a time to do so. If possible, I like to shoot for either the 11th or the 18th.
Hello! I can get you checked out on the laser cutter on the 11th. I’ll be at the space doing a cutting board workshop and could check you out during our lunch break around 11:30am. Does that work for you?
Yes, April 11, 11:30am. You can ring the doorbell if the door’s locked, the space doesn’t open until noon. You won’t need anything else for the check-out, but if you’re bringing files to cut, you may need material. See you then!
