Affected Tool or Resource: Horizontal bandsaw in blacksmithing area
Team, Group or Volunteer who usually handles this type of ISSUE or REQUEST (Please tag using the @ symbol. Start by typing @TEAM_
to find most responsible teams): @TEAM_Blacksmith
The auto-stop switch on the horizontal bandsaw broke into pieces. It had been giving us trouble before, and finally gave out.
I removed the switch and will find a replacement. Without the switch. there are two choices: the power button starts the saw and latches on as usual, but does not stop once it cuts through, or the saw only operates while holding the switch on. I chose the second option. The saw is still usable, but you must stand there and keep the switch pressed.
I will find a suitable replacement switch, and also look at rebuilding the power box altogether, since it’s pretty corroded and nasty inside.
