ISSUE or REQUEST: Clausing Drill Press needs repaired and tested
Affected Tool or Resource: Clausing Drill Press
This tool was left behind for us by Fluid Chillers. It needs a plug installed at the end of the wire, and then needs to be relocated to a 440v capable outlet so that the machine can be tested. The machine then needs to be tested to determine whether we will use it in one of our areas.
