The pressure regulator on the small forge is not functioning properly. The dial shows no changes when the nob is turned. The flame also doesn’t change when the nob is turned. @Clifford_Bohm could you take a look at it?
Should we not use the small forge until Cliff has looked at it? If so, we should put some sort of sign on it so people know.
I did put an out of order sign on the small forge.
I’ve looked at this, and used it a few times without any issues. So… I’m not sure what to do about this. I’m assuming it’s solved unless there is some more data.
